Rack Limiters?
I need to install some rack limiters on my stang, im running 17x9 rims on a 91 fox. While I"m planning on a tubular K/arms and a coil over sometime this summer, as well as a new rack. I need to know how many limiters i should install in a stock rack w/ stock control arms. I have 6 limiters, 3 for each side, do I need all 3? 2? or just 1?
Dont have a clue
I'd only add 1 and see if that stops the wheels from rubbing on the A-arms.
I have the 17X9 also and I added 1 more per side which is 2 per side now because it came from the factory with 1 already in it. |
Well I'll check and see if one is in there, but if not I'll add two... I don't want to keep replacing rack boots and those crazy clamps.
when i had 9 inch wheels on the front of mine i put two more on each side. never tried with just one but two made it stop rubbing fine.
