which intake manifold
6psi supercharger question
if i install the sc without the fmu will it be fine to drive lets say 5 min to the shop down the street? not sure if i know how to hook it up
Yes, it will be completely safe to run the car without the FMU. Just try not to get too heavy on the throttle before getting the car tuned. Also, since your mods are so minimal and since you are only going to run low boost, you may get away with just running the 30lb injectors. Again, a dyno can verify that. Once you start throwing on big mods, then you will need to step up to some bigger 42lb injectors. But for now, you will be fine.
And agreed, boost is addicting, i dont even have my car tuned and ive already been looking at buying some smaller pulleys!!!!!
daltron
04-28-2016 08:10 PM
