restoring 1/4 window molding ... fail
Old 05-05-2009, 07:17 AM
90Mustang_GT
90Mustang_GT's Avatar
Default restoring 1/4 window molding ... fail
I thought i had this all worked out, till i was taking the tape off. Well, my moldings were deteriorated, and very rough. First i sanded it up to 220 grit. Finished w/ 400. from there, there were still bumps, so i used a high filler primer, and after about 10 coats it was smooth. Next was painting it with some black trim paint in the rattle can. after about 4 coats, i started to take off the masking tape, and along with it came some paint peeling right off the edge, showing the gray primer. what can i do to avoid this from happening? It is also very easy to flake off.
I spent alot of time doing this, hoping it would be better than befor, but its no better, just wasted my time. I cant get any pics of it now, cause im at my school. my photobucket is americankid .... photobucket.com/americankid or something.
-Any help would be nice.
90Mustang_GT is offline
Old 05-05-2009, 07:57 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
the time you spent doing that I could of replaced the seals with new ones...either way run a razor blade down the seam between the tape and seal before pulling tape at and angle away from the body.
mjr46 is offline
Old 05-05-2009, 08:23 AM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
^^ If there were seals to replace them with. Masking tape can be a bitch sometimes. What tape are you using??
projectresto83 is offline
Old 05-05-2009, 08:31 AM
mjr46
mjr46's Avatar
so use these
http://www.latemodelrestoration.com/...0%201&comp=LRS
mjr46 is offline
Old 05-05-2009, 09:13 AM
JD1969
Pro. B.S. caller outer
JD1969's Avatar
He could just remove the 1/4 windows.
JD1969 is offline
Old 05-06-2009, 04:25 PM
Hawaiian5.0GT
Hawaiian5.0GT's Avatar
Originally Posted by mjr46
Are the trim covers any good?
Thanks Chuck
Hawaiian5.0GT is offline
Old 05-06-2009, 05:15 PM
Mike516882
Mike516882's Avatar
and put what there instead. this is of interest to me seeing that my window is broken on the drivers side!
Mike516882 is offline
Old 05-06-2009, 05:24 PM
Five0hFox
Five0hFox's Avatar
If you ask me, use better paint. I think the whole rattle can thing is the reasoning for the chippng.
Five0hFox is offline
Old 05-06-2009, 06:47 PM
JD1969
JD1969's Avatar
instead of taping them off.
JD1969 is offline
Old 05-06-2009, 08:21 PM
mjr46
mjr46's Avatar
they sell the replacement 1/4 windows, without the mustang logo imbedded in them...they are pricey.
mjr46 is offline
cr620
10-03-2022 10:18 PM
lincolnshibuya
07-05-2020 03:05 AM
CS2007
06-25-2019 09:45 PM
jrrhd73must
10-02-2015 09:17 PM
GLOCKer
09-28-2015 07:36 AM
Quick Reply: restoring 1/4 window molding ... fail
