Gt40 heads
Gt40 heads
i have just been wondering what kind of gains i would get by putting the gt40 heads on my 89 5.0. i was also wondering what the difference is between the gt40 p style heads or just the gt40 thanks
My set up is:
GT40 heads from a cobra
1.6 Roller Rockers (Pro Form)
Comp Cams 35-302-8 cam
Cobra Upper and Lower
.550 lift Springs matched in the heads for the cam
BBK equal length shorties
Full exhaust
24lb injectors
the idle sound is mean and at 2500 rpm the car comes alive.
Full exhaust
24lb injectors
Gt-40 heads are not bad but i would even try to go with the new Turbo Swirl heads, there pretty cheap and defently a little better than the regular gt40s, but there a lot cheaper than the big brands with better heads but you get what you pay for. The Gt-40ps are primarily off the V8 explorers, they have small exhaust valves but obviously youll get a gain over the stockers but not much and considering you have pretty much everything else set up already i would try and get a decent set of heads to complete your set up, dont settle for junkers
