where to mount aftermarket fuel pump?
05-31-2009, 12:47 AM
Where do you racers usually mount your aftermarket fuel pumps on the foxes? I got a holley 110 and i dont have a clue where would it bolt up to good.
thanks guys!
05-31-2009, 03:39 PM
05-31-2009, 06:30 PM
The Rogue Mod
why do you need a second pump?
here's where mine is
06-01-2009, 12:27 AM
I don't. I took my 4cyl pump out of the tank and replaced it with a rubber hose, then got an aftermarket one because the old pump was only pumping around 30gph or so..
Thanks for the pic, that will help.
06-01-2009, 06:56 AM
The Rogue Mod
OK, so why didn't you just put the new pump in it's place?
06-01-2009, 11:32 AM
Moderator
No longer running this pump, we now have a holly red, but in the same location,
It's the big flat spot on the frame behind the gas tank, so lay under the car from behind, go past the gas tank up and look up.
06-01-2009, 04:25 PM
Quote:
Originally Posted by
PRO50SC
You do know on carbureted engines the fuel pump is outside the gas tank right?? plus how would you fit a holley blue pump in there..
06-01-2009, 06:31 PM
Got a welder? Fab up some brackets, that's what I do anyway.
06-01-2009, 06:40 PM
I wish I had a welder lol!
06-02-2009, 04:24 PM
Got it done this morning. Thanks for the help.
10-26-2015 05:01 PM
pimp2303
09-17-2015 08:45 PM
09-16-2015 07:53 PM
SteelerNation82
09-16-2015 07:11 AM
rksnow1
09-14-2015 08:46 PM
