i cannot get the pinion shaft out of the case i removed the pinion shaft lock bolt and the pinion shaft will not budge? any tips this thing is driving me crazey!! help mike
I have been beating that pin for 20min with no movement at all? could anything else be done to get it apart, i am not using the traction lok or the gears in there so if there is another way to get it out i am all ears. thanks guys mike
Taking out that pinion shaft is the only way to get c clip access and therefore the only way to take your rear apart. Use a 3/8" ratchet extension and pound that bitch out of there.
thats what the haynes manual said i was hopeing there was a way around it, thats exactly what i have been using a 3/8" extension it dances around a little bit when you hit it, moves in and out about a 1/16" but thats it i would bring it to a shop but at this point it is all taken apart on jackstands....
