Font End Shake
06-06-2009, 04:11 PM
I find the balljoints will sqeek, stick and break right off the car long before they shake.
Start with the tires and keep in mind, an out of round tire or a tire with a flat spot can still be balanced 0 / 0.
06-06-2009, 07:48 PM
Bad ball joint in my stang caused extreme vibration through the steering wheel at 65+ back when my car was stock.
06-23-2009, 08:51 PM
If the shake/vib smoothes out during cornering...does that point to the ball joints?
06-23-2009, 09:00 PM
jack the car up, so both wheels are off the ground, perform a suspension inspection with a pry bar and flash light.
06-23-2009, 09:13 PM
D.R. THE PATHETIC DORK
06-23-2009, 09:38 PM
Quote:
Originally Posted by
aode08
Pry bar and a flash light???
06-23-2009, 09:41 PM
mjr46
balance the tires
New runners and new tires.. But i will check and see if they used sticky weights or the ones you beat on.(they f-ing better not have beat weights on my centerlines)
4cylinderplus2
10-09-2020 07:45 PM
kevsgt
10-09-2015 10:12 PM
88 orangepeel notch
10-05-2015 09:03 AM
UrS4
09-30-2015 10:13 AM
marc954
09-29-2015 11:18 AM
