still runs like crap...
ok so ever since last tuesday my 5.0 has been running like crap...
I have done the following
cleaned out IAC, cleaned the MAF first, checked the Dizzy
pulled codes
got code 33, 41, and a few unrelated ones or EGR, and running lean
cleaned out EGR, like I REALLY cleaned the EGR...
still stalls at cold start, runs a little smoother, but still not the best...
where to go from here? I checked the HEGO ground strap, thats fine, the O2s are seated in their bungs...
last thing I want to do is take it to a shop...
pulled codes
did you try switching the 02s?
as far as the cold start, my ect sensor wasn't getting a good connection and caused problems one time. It never did throw a code. I put some contact grease on the connector and my problem cleared up.
say if you are in front of the car looking at the engine, you will see a metal pipe going into the intake to the left of the distributor. There will be a 2 wire sensor teed of that pipe.
You can run a wiggle test to find the connection problem.
thanks, yeah I just want to hopefully fix this issue tomorrow. once the car is running, it runs well, idle is still a little rough, but sometimes it will stall 2-3 times before it will run...
