caster/camber plates
I see you have a newer model stang.
I don't know if this applies, but the fox body needs offset rack bushings, and a different length, sway bar end links(shorter) to correct the geometry fully.
Some one on here should give you performance alignment settings if you would like as well.But this is just your GF, I would stay stock and ZERO IT IN, AND JUST GET whats needed to stop tire wear.
thats the idea is just to get whats needed to get the proper tire alignment. also thats why i asked about some good DD struts and shocks because her current ones are pretty much done where its been lowered for so long and they are 11 years old so its time for new ones
maestro1024
09-21-2015 02:40 PM
