Baseline Dyno Run
numbers are a little weak compared to mine but not too bad. i went to a dynojet as well when my car was stock to get a baseline with basically the same mods you have. all i had was 3.73s, bbk shorties, o/r h-pipe, mac mufflers, 12* timing, underdrives and a 75mm MAF for 19# which was making it run really rich, 11.6 afr all the way through
she put down 215rwhp and 274rwtq
do you have an AOD or 5 speed? mine is a 5 speed
His sig says he has a 5 speed.
I'm pretty sure the significant amount of oil my car burns is because of a bad valve. Not to mention the car was hot as hell from a 45 drive to the dyno in 85 degree weather and suckin through a paper filter in the stock air box.
Might be other flaws with the car as it hasn't been scanned in two years, got an OBD1 scanner coming in the mail.
If it blew on the dyno... tow it home and build a new motor now rather than later. No different than if I was flogging it at the dragstrip.
