Help me pick some wheels & tires. (back spacing ?)
Well the '85 4-banger i bought to DD doesnt look like it's going to work out. I've thrown about $200 at it to get it running right to pass emmission's, and it STILL wont pass.
I know I can sell it for $800 in a heart beat, and its possible to get $1,000 for it, if i get lucky. Im going to buy 2 more Weld Draglite rim's to run street tire's on. My problem is i dont know much about back spacing and such. the one's im looking at are as follow's. 15 in. x 8 in. 4 x 4.25/4.5 in. Bolt Circle 5.5 in. Backspace Link to the rim. http://www.summitracing.com/parts/WLD-90-58040/ These will work right? or is 5.5 to much back spacing? How big of a street tire can i go? im thinking 255/50/15 or 255/60/15 depending on the tire i can find. A 28" tall tire would be prefured. (or 235's dont need anything as wide as 275's for daily driving) Also what's a good STREET tire to run? Does NOT need to "hook" great for "racing" but i would like VERY VERY VERY good wet traction. Sick and tired of sliding around in the rain with these micky thompsons. I cant drive this thing right now in a light rain without the rear end moving around even when already up to speed and not in the throttle. any help would be great. thanks. |
With a 5.5 backspacing the wheel will sit about even with the inside of the quarter panel. You will be fine there. A 28 inch tall tire is pretty big man. Its nice for a drag tire but I wouldn't run it on the street. How much have you dropped your car? The 275/60's on my 93 are 28 inches tall and they look massive. I would run 245/50 but I can't find any decent priced tires for 15's in that size. Just some dunlops on summit that are over $200 a piece.I think I am gonna get a set of 235/60s for everyday driving. That is slightly over 26" tall.
http://s284.photobucket.com/albums/l...snegerRear.jpg Thats my 275/60/15. It belongs on a truck lol. |
i want 28" because of the 4.10 gears. help a little with the RPM's
BFgoodrich's radial T/A's make both a 255 tire and 235 tire that are 28" good to know about the back spacing........ 100+ view's and only one reply? weak. |
w/ a 26" tall tire 10.5" is widest
i kinda think w/ 28's you might be limited even more all street tires suck, so imo get the cheapest ones w/ the best warranty and call it a day |
Originally Posted by nitrous_bob
(Post 6338912)
Especially with 15's. The good street tires are usually in the 16's and up now a days.
A 235/70 is gonna give you a huge sidewall and cause less stability in the rear. I would just stick with the height of the tire you have with that drag radial to tell you the truth. |
yea sound's good. I was just thinking taller would be better for a little lower RPM's on the highway.
If your saying 28" street tire's wont fit, then what about the 275/60/15 mickey's im gonna buy once the control arms are on?? I thought those fit fine?? |
a 275/50/15 rubbed like hell for me, even normal driving in the turns, but i have eibach springs on my car , and it was the width... but they really chewed up the sidewalls
maybe find a "used" tire of that size you want and try it out ? i agree for street driving a 28" tall would help a lot if you went 28 tall and 9.5" wide ??? that might work not too sure though... and BTW.. the cars looking good.. you still spraying it ? "still slow" ? c'mon.. really ? throw me a time ?? my 'vert was about 4000 lbs w/ 1/2 tank and me in it and i'm only 150 , but you gotta be close to mid/hi-12's or there already. |
(Post 6339730)
maybe find a "used" tire of that size you want and try it out ? i agree for street driving a 28" tall would help a lot if you went 28 tall and 9.5" wide ??? that might work not too sure though... and BTW.. the cars looking good.. you still spraying it ? "still slow" ? c'mon.. really ? throw me a time ?? my 'vert was about 4000 lbs w/ 1/2 tank and me in it and i'm only 150 , but you gotta be close to mid/hi-12's or there already. for street tire's i dont really care if they are wide or not, it would just help so when i do get on the loud pedal im not sliding around all over the damn place. Thank's for the compliment, never really gave the car a good wash and took picture's on the same day, so its always looked like crap in the picture's ive posted in the past haha. Well i havent sprayed it sence i toasted the AOD. if you remember you helped me when i first started spraying. took 2 second's off my ET with a 50shot. a lot of that has to deal with the fact that im at 5880ft above sea level. DA at the track on a GOOD day is 7200-7500. Now that the T5 is good and broken in ive been meaning to use the bottle again. but first my nitrous silinoid was leaking, got a new one, had to get new fittings, then found out my purge silinoid was leaking too. so now i have a good nitrous and fuel noid, but no purge, which i dont like. And the bottle warmer is ****ed, becuase the fitting for the wiring right by the heat pad melted for some odd reson, so i gotta fix that....... haha. My 'vert is 3500 with me in it, im 250lb. thats with about a 1/4 tank of gas or just under. haha, well i dont wanna disclose what it run's up here, but the DA correction to sea level put's me at low 13's all motor. ive smoked some LS1 T/A's, a new R/T challenger, WRX's and such of that caliber. so its pretty quick for what it is. im just itching like a crack addict to use the bottle again :) just kinda scared from all BS that happened last year..... so im going to get the little things fixed, and make sure i have another vehicle to drive haha. the '85 i bought was sapposed to replace the 5.0 for daily driver duty, so i wouldent be scared to use the nitrous again incase something bad happens again. But now its not going to work out, as it wont pass emissions, and my truck that i have for when it snow's has 170,000 miles so i dont really trust it......... lol, as you can see, its alot of BS right now. |
trust me bro... i've been there all too often
i expected this notch to be in the 11's LAST summer, but guess what.. still on a broken trans, and my heads and intake are still on the shelf waiting for the last 2 years :( effin economy, and wife that doesn't like money going on the car... blah blah blah... story of my life |
