Need help no spark 5.0 HO
My 90 5.0 HO mustang has no spark. I took it to the dyno shop to get tuned and set up drove back home parked for to days and does not wont to start. No spark is coming out of the coil, so I swaped it with one that I know that worked and still has no spark. Swap out TFI mod still no spark, found that the start signal wire that goes to the TFI has no power and I know that wont make it start. So I jumped a power wire to the start signal wire for the TFI and Still has no spark. Also has no power going to the positve side of the coil. Note I am running a msd box, its gust so wierd that every thing was working great then I parked it and two days after parking it it did not wont to start. Any help would be a great help to me.
I well try and hook it back up to the way its is from factory and im going to see if my msd box is no good. I have heard that the 6AL boxes go bad but this box is only 6 months old, but il get it looked at any way to eliminate any possibility.
Thanks for the reply I found that the MSD box was blowing out a fuse every time i go to start it. Removed MSD box and ran it gust with the coil and started right up. NOTE TO SELF MOUNT MSD BOX FARTHER AWAY FROM HEADERS. Gust to let you guy know I have a 5.0 egine and trans from a 90 Mustang in a 79 mazda RX7. Thanks for your guys help now I need to get my MAD box repair some were
Matt's 95 Stang
10-05-2015 07:16 AM
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
