It Works! FINALLY!
It Works! FINALLY!
Yes, Finally, It works! I didn't think it would ever happen but damnit perseverance finally paid off. Couldn't really come onto 'er tonight because it had just rained and she would fly sideways through 2nd and 3rd but it feels strong and sounds awesome! I'm exhausted and going to bed, but will post up build pics tomorrow. Cheers!
The engine. I tore out the stocker back on March 15th. Did a complete h/c/i swap and had a ton of insane problems straight from day one. Got it working well, but it kept spark knocking and running lean and no matter what I tried it didn't work. So I tore it apart and went carbed and after a bunch of other crazy ordeals, it finally works!
Modifications:
-Main bearings
-Cam bearings
-All new gaskets
-New oil pump
-Crank polished
-New thermostat
-Timing chain
-Comp xe270hr cam
-Comp lifters
-Trickflow pushrods
-Trickflow 1.7rr's
-Trickflow twisted wedge heads
-Edelbrock Rpm Air Gap Intake
-Holley 650 dp 4150 series
-K&N breather
-Meziere electric waterpump
-A/C and Smog delete
-Under drive pullies
-Ultrasport aluminum rad
-Dual 12" Flexalite electric fans
-Mallory Hy fire Ignition
-New fuel lines
-Mallory FP regulator
-Eaton carrier with 31 spline Mosher axles. And corresponding components for the 5 lug conversion.
-Walbro 255 lph electric fuel pump
-Drive shaft loop
-17x9 chrome bullits on all corners
-4:10 gears
-Steeda Aluminum adjustable upper and lower control arms
-Steeda Superlite Drag Springs
-Tokico shocks
-New bushings all the way around.
-Subframe connectors
-Hurtz linelock
-BBK unequal length headers,
-Mac 2 1/2" offroad H pipe
-Magnaflow 2 1/2" Exhaust
-Centerforce df clutch
-Tko500 transmission
-Interior I replaced the steering wheel, center console added a cd player and changed the speakers in the doors, fixed the power locks that didn't work and changed the li'l black squares behind the door handles.
-Hoosier 26x10 slicks for racing.
Probably a lot more but that's all I can think of off the top of my head.
-Main bearings
-Cam bearings
-All new gaskets
-New oil pump
-Crank polished
-New thermostat
-Timing chain
-Comp xe270hr cam
-Comp lifters
-Trickflow pushrods
-Trickflow 1.7rr's
-K&N breather
-New fuel lines
-Drive shaft loop
-4:10 gears
-Tokico shocks
-Hurtz linelock
Well after my recent excessively long 24 hour road trip (one way) to Virginia, it came to mind that 1467 ran of the drivers side plain. So I started thinking about a huge vacuum leak.. or heck a rag or something shoved in there.. I've seen stranger things in my life.. but anyhow. I tore the carb off and there it was.... a motherf'n hole right under the carb where a plug needs to go in the back of the intake. Plugged it, set my timing and gave her hell. Embarassed... ya! happier... Definitely!
