I suppose these are overdue? ...Pics!
Well I've been a forum member for over 8 months now.. So I suppose it's probably time to show you all just what I got.. Well here ya go! Hope you enjoy...
ps: don't ya suppose the back tint cracked taking pictures...ugh.. anyhow don't mind it. Cheers!
Modifications:
-Main bearings
-Cam bearings
-All new gaskets
-New oil pump
-Crank polished
-New thermostat
-Timing chain
-Comp xe270hr cam
-Comp lifters
-Trickflow pushrods
-Trickflow 1.7rr's
-Trickflow twisted wedge heads
-Edelbrock Rpm Air Gap Intake
-Holley 650 dp 4150 series
-K&N breather
-Meziere electric waterpump
-A/C and Smog delete
-Under drive pullies
-Ultrasport aluminum rad
-Dual 12" Flexalite electric fans
-Mallory Hy fire Ignition
-New fuel lines
-Mallory FP regulator
-Eaton carrier with 31 spline Mosher axles. And corresponding components for the 5 lug conversion.
-Walbro 255 lph electric fuel pump
-Drive shaft loop
-17x9 chrome bullits on all corners
-4:10 gears
-Steeda Aluminum adjustable upper and lower control arms
-Steeda Superlite Drag Springs
-Tokico shocks
-New bushings all the way around.
-Subframe connectors
-Hurtz linelock
-BBK unequal length headers,
-Mac 2 1/2" offroad H pipe
-Magnaflow 2 1/2" Exhaust
-Centerforce df clutch
-Tko500 transmission
-Interior I replaced the steering wheel, center console added a cd player and changed the speakers in the doors, fixed the power locks that didn't work and changed the li'l black squares behind the door handles.
-Hoosier 26x10 slicks for racing.
Probably a lot more but that's all I can think of off the top of my head.
-Main bearings
-Cam bearings
-All new gaskets
-New oil pump
-Crank polished
-New thermostat
-Timing chain
-Comp xe270hr cam
-Comp lifters
-Trickflow pushrods
-Trickflow 1.7rr's
-K&N breather
-New fuel lines
-Drive shaft loop
-4:10 gears
-Tokico shocks
-Hurtz linelock
Actually in the plans^ I got steeda drag springs and adjustable upper/lowers, so rear ride height isn't an issue.. I can control that.. but I got a set of Eibach pro lowering springs for the front that I'm gonna install whenever I get the time.
