Finally I decided to Tear down my sleeper !
Hey guys, Here are some pics of my new build, I am waiting for some responses before I go ahead and order my parts form Summit Racing, this is my first time I am doing it my self, I seen it when my mechanic did it but not me alone ! Well I am a little bit scare, this is what I am thinking to order so I need your input.
Motor Mount & tranny mount, MSD Dist complete and MSD 6 AL 6420, Cobra INtake manifold upper & Lower, TF aluminum Cylinder Heads, Twisted Wedge Street, Aluminum, Assembled, 61cc, Ford Racing blue anodized Rocker Arms, Stud Mount, Full Roller, Aluminum, 1.6 Ratio, Fits 3/8 in. Stud, 303E cam, new water pump, new timing chaing and cover, new rad hoses blue, new fuel rail prof. products, new oil pump H.V., valve covers ford racing black with red letters, smog pump eliminator ( should I plug the tubes in the back of the block) well thats all for now I want to order.
Hee are some pics, I am doing also at the same time body job and paint job, She is going to stay black but with some purple pearl, but the F%%^& weather in Canada had been cold ! waiting for a sunny day to finished her.
Might as well use the Trick flow stage 1 cam with the heads, maybe even the stage 2. Don't buy the smog pump elim., just lose the pump and get a shorter belt. there are thermatic plugs you can buy to plug egr ports.
Well, there is not going back, I already place my order and I listened to you guys, I did order the Trick Flow aluminum head with the Stage 2 cam and the cobra upper and lower intake manifold, I have a pair of shortie ready to go in, should I install them on the engine while it is in the engine stand ? also the same with the starter, should I mounted it before I put back my engine ? Thanks guys I will keep you updated with my pics and the numbers after I finish with her.
Thanks Five, I will do that, I will have many question since this is my first rebuilt but is there anyway to find out what studs will fit my Trick Flow Stage 2 cam with the Heads and a set of Ford Racing rocker roller arm ? or do I have to mount the head and the cam and then measure it ? if so how do I measure it?
