Cervini's cowl hood
Cervini's cowl hood
Im looking at buying a cervini's cowl hood but Id like to see some pictures of them installed on some cars and some pictures off the car if you have them.
And to those who have the hood I have a couple questions. Do you run pins? Is the underside finished? does the cowl curve back or come straight down at the cowl grille?
Thanks for all info.
im not sure on the age of the hood, a few years old anyways. bought it used, needed a little bondo work.
the under side of mine was unfinished. i bought spray on truck bed liner and sprayed it. it looks good imo.
if you do it, scratch the surface first. if you get it in a spray can; 1 can = 1 coat, if you get the jug/can you can run it through a spray gun and it works that way, just scratch the surface first, it stick better.
