Disappointing Trip to the Track. Need Advice
Old 08-02-2009, 10:23 PM
87Stallion
87Stallion's Avatar
Sad thing is the car appears to be running good.
87Stallion is offline
Old 08-02-2009, 10:27 PM
w8less
w8less's Avatar
spinning aint winning
w8less is offline
Old 08-02-2009, 10:29 PM
87Stallion
87Stallion's Avatar
No **** sherlock
Old 08-02-2009, 10:32 PM
w8less
w8less's Avatar
Originally Posted by 87Stallion
I did spin pretty bad through 1st and part of second. Any ideas where I can improve?. It didnt matter what RPM I launched at the times stayed between 14.6 and 14.75
listen you ingrate you said you were spinning and asked for advice dont be a cheap *** and buy some suspension for the car so you CAN HOOK UP and stop getting a pathetic 2.1 60ft time
w8less is offline
Old 08-02-2009, 10:35 PM
87Stallion
87Stallion's Avatar
I just put all new u/l tubular control arms on the rear if you'd read my original post, you would have seen that. I was however running 255/60/15 street tires. I know Drag radials would help.
Old 08-02-2009, 10:36 PM
txjason1
txjason1's Avatar
I am a little worried about my ET's now too up here in Colorado....dang I didnt think it was gonna affect me like that....we will see next weekend at Bandimere or Pueblo.
txjason1 is offline
Old 08-02-2009, 10:51 PM
w8less
w8less's Avatar
what struts and shocks? is the car transferring weight? did you adjust your pinion angle? IC?
are you dumping the clutch and shocking the tires? slipping the clutch?
what "tubular upper and lower control arms"? There is more to suspension than upper and lower control arms
w8less is offline
Old 08-02-2009, 10:55 PM
87Stallion
87Stallion's Avatar
I am running new stock style Shocks and struts. I am running the summit brand upper and lowers. I did not adjust my pinion angle. I'm not dumping the clutch when I launch.
Old 08-02-2009, 11:10 PM
w8less
w8less's Avatar
im done. goodluck at the track next time.
w8less is offline
Old 08-03-2009, 02:34 AM
Dj_Seph
Dj_Seph's Avatar
Wierd. I ran a 14.7 when I was stock and I live in AZ. O.o
Dj_Seph is offline
Quick Reply: Disappointing Trip to the Track. Need Advice
