seat replacement
on some if i remember right bolts stick ou and some thread in. my 93s stuck up in the front 2 and threaded in the back. my 86 i know is a fit so at least 86-93 fit, the early 79 - 84 might be differant i had seats from a 82 gt and i think they may have been differant. the seats can be removed from the seat frame or whatever its called. ive installed mustang seat on t bird power frames before, they are close but required modification.wonder if sn95 seats fit? hmmm. good luck check for cracks in the floor pan while your at it, i had to weld a friends up
79-04 seats fit. Just use the corresponding tracks as well. If you are short and have a hard time looking over the steering wheel I would use the 95+ seats bc they set you up about an inch higher. That and I think they are more comfortable.
really, so do the 95 seats have a compatible track too?as for my 86? i hate how low my seat is but its sorta broken again.backing, the leg, its all been welded atleast once.so 94 seats are differant than 95?
Sorry I meant 94+. Use 94-98 tracks with 94-98 seats and 99+ with the same seats and you will be good to go. If you don't know this already ALOT of parts from the 94+ can fit on/in a fox. The mounting points are the same. There are alot of people on here with 94+ seats in their fox and I will have mine bolted down next month when I get home for R&R.
