Where can I find a good NWC case?
On my NWC T-5 transmission, the bearing cap is weeping gear oil past the case there. My brother just re-built it 700 miles ago, and he told me that if it leaks there, the hole is worn out and a new case is the only way to repair it. It slid into position, not pressed in.
Where can I find a new or at least a good case for my NWC? I know they don't make them anymore(only the WC), but I was wondering if you guys know anything.
Thanks!
Thanks!
there is an o-ring that goes on that bearing cap and is pressed into place with the o-ring on the cap and to flacilitate it to press into place I put a small amount of silicon on it otherwise it'll often tear and cause the leak, I seriously doubt the hole is worn, the bearing cap is stationary and there is nothing there to cause it to wear, I'd call it installer error!!!.....after pressing it into place carefully i ADD A HALF quart of tranny fluid and tip case up so fluid covers bearing and let it sit for a hour or two to insure no leaks, , never had one leak due to age and when it is installed properly
Woah, wait a minute. There's an o-ring that goes on the cap bearing? On a Non-world class case? You're not talking about a World Class, are you?
Also, like I said, the cap slid in, didn't press in.
Could you explain for me, please?
Faolan65
08-27-2015 06:40 AM
Faolan65
Arizona Regional Chapter
08-25-2015 09:24 AM
