92 5.0 LX Pass. Window motor
New member here, About to pull the int. panel off the passenger door and replace the motor. Neither the driver side switch or the pass. side switch will raise it. Yes, it is in down position.
Is it a complex replacement? Advice? If an applicable thread exists, pls. point me to it.
Thanks in advance, Larry
I'm not totally sure on this, but you might find that the motor is riveted to the regulator. Sometimes they are, sometimes they are bolted. If its riveted, just have a drill bit a couple sizes larger than the hole in the center, and drill straight through it.
Also, the problem could still be in the switch. The passenger switch will not work if the drivers switch doesn't. The power is routed that way. Verify that power is entering and exiting both switches before you go crazy trying to replace the motor.
its probably just the bushings inside that need to be replaced, open it up and see if it contains three round plastic bushings. if its anything like the convertible rear motors that was my problem and was a 8 dollar fix from autozone.
note: usually the bushing will be in pieces
the bushings that i was refering to are the plastic gear bushings inside the motor, there are three of them. they get bridle and break.. my window would go down but not go back up. i opened up the motor and the bushings were in tiny pieces. i replaced them and wala it worked.
We carry new replacement motors,if you guys want to check them out here's a link to them.
Mustang window motors
DreadPirateRoberts
09-26-2015 02:11 PM
jaiidutch
09-14-2015 10:29 AM
