View Poll Results: Well, which one guys?
Comp 35-425-8 Retrofit
0%
Comp XE274HR
0%
Comp XE282HR
0%
Different
0%
Voters: 0. You may not vote on this poll
Pick one of three, final cam decision!! Vote Now
Old 09-11-2009, 05:03 PM
JayBanion
JayBanion's Avatar
Default Pick one of three, final cam decision!! Vote Now
Ok so here we go, I have narrowed it down to three cams. 1. The comp 35-425-8 xtreame energy retrofit cam. 2. Comp xtreame energy XE274HR 3. Comp xtreame energy XE282HR
1. http://www.summitracing.com/parts/CCA-35-425-8/
2. http://www.jegs.com/i/Comp-Cams/249/35-518-8/10002/-1#
3. http://www.jegs.com/i/Comp-Cams/249/35-522-8/10002/-1#
The third one may be a little to much cam for my motor but thats why I am asking you guys. This will be my final desicion, Im not going with any custom grind at this time, that will be my next motor. Will all three of these work, remember Im using the stock 88 shortblock, so I dont want any PTV contact. Any experiance with these cams. The first one is what the guy from comp told me to use.
Jay
JayBanion is offline
Old 09-11-2009, 05:52 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
I have one simialar to the first one as well as the third one with all the proper valvetrain hardware if interested...I had the first one in a stock bottom end with performer heads and no ptv issues, put you always must check first
mjr46 is offline
Old 09-11-2009, 08:12 PM
JayBanion
JayBanion's Avatar
Will let you know, gotta decide soon though so I can get my heads out to the shop, need to know what springs im using.
Old 09-11-2009, 08:14 PM
mjr46
mjr46's Avatar
springs will reflect the cam you use, choose a cam then match the springs to it
mjr46 is offline
Old 09-11-2009, 08:18 PM
JayBanion
JayBanion's Avatar
right, thats why I need to make my cam choice very soon, so I know if i need to get the spring seat machined so I can get these heads to the shop
Old 09-11-2009, 08:31 PM
mjr46
mjr46's Avatar
all of those cams you chose should require a dual spring set up and on stock ford heads will require seat machining
mjr46 is offline
Old 09-11-2009, 08:47 PM
JayBanion
JayBanion's Avatar
Ok so count the last one out, I was reading a few old posts and it sounds like the 282HR is to much of a cam for my set up. So mjr, you seem to have a vast amount of knowlege and you have been very helpful so far. Out of the first one and the second, what do you think will be best for my setup? oh and compared to that thumper cam you have
Jay
Old 09-11-2009, 08:51 PM
AdderMk2
Banned
AdderMk2's Avatar
you should avoid the first one... you do NOT want a retrofit camshaft
im still partial to the xe276HR for gt-40 and gt-40P headed builds
AdderMk2 is offline
Old 09-11-2009, 08:56 PM
mjr46
mjr46's Avatar
personally I'd rule the last two out, expecially if you are using gt-40p heads...don't know how true this is but from what I have read about gt-40p heads peak flow is up around .500 lift, , your head choice will be the crutch here
mjr46 is offline
Old 09-11-2009, 08:57 PM
JayBanion
JayBanion's Avatar
Whats your reasoning adder?
Quick Reply: Pick one of three, final cam decision!! Vote Now
