The New Stang !
#21
http://i118.photobucket.com/albums/o...Mustang025.jpg
#22
Coilover replacement?
OK, I have a set of Strange struts with a UPR coilover set up...It seams like I cannot adjust the height due to the inside treads do not turn in the cylinder since the they are set to the lowest setting. This seems to be the only set up without the 2 rings that you loosen and adjust? There is a Alan screw you take out before adjusting nut when you grab hold of the spring and inside threaded tube the only thing that turns is the spring? Here is a picture link...Any shead any light in this pain in the A** http://i118.photobucket.com/albums/o...Mustang025.jpg
