Plugs 1,4,6,8 WET.. (oil) why is this???
Old 10-11-2009, 10:13 AM
F150 StrokerCobra
F150 StrokerCobra's Avatar
Default Plugs 1,4,6,8 WET.. (oil) why is this???
i noticed the engine was smoking grayish blue lastnight... i cheked the plugs today and saw that cyl 1,4,6,8 are wet.. the other ones are burning fine..
it is a new engine below 500 miles... maybe the rings havent seated properly yet?? or what could be wrong here?
F150 StrokerCobra is offline
Old 10-11-2009, 11:26 AM
lxman1
lxman1's Avatar
Perhaps the intake is sucking oil from the bottom side of the ports? Odd that only 4 of 8 are doing it.
lxman1 is offline
Old 10-11-2009, 03:07 PM
F150 StrokerCobra
before it was only 1 and 4 Cyl... now its gotten to the other side as well i suspect the intake sucking oil.. but im gonna do a compression chek to chek the rings first then im gonna chek the intake..
just talked to the guy who build the engine for me
he said chek compression to see if the rings are ok!
then chek the valve seals ( his job )
then chek the intake...
Old 10-11-2009, 03:15 PM
motorman524
MF Informant
motorman524's Avatar
did you build the bottom end?
motorman524 is offline
Old 10-11-2009, 03:40 PM
F150 StrokerCobra
nope.. it came from Ford.. the engine was a REMAN. engine from ford.. 0.0 miles on it.. brand new..the engine shop only swapped the cam and did some machining on the head to the valve seal fit..
Old 10-11-2009, 08:43 PM
lxman1
lxman1's Avatar
My money is on the intake gaskets.
lxman1 is offline
Old 10-11-2009, 09:18 PM
F150 StrokerCobra
i think your spending your money right.. today i started it so cold start and its not smoking or smelling like burnt oil.. Hot engine.. (dragracing) the more it expands and letting the oil in cold engine not so much... im gonna chek compression first then the intake gasket..
BOB ROME
07-26-2023 01:54 PM
lincolnshibuya
12-08-2015 04:37 PM
Dathan
10-05-2015 05:52 AM
breaking
10-02-2015 01:27 PM
wraith777
09-28-2015 10:49 AM
Quick Reply: Plugs 1,4,6,8 WET.. (oil) why is this???
