89 GT Vert...new window regs?
I need new ones but cant seem to find them anywhere.....89 GT convertible.....for the driver and passenger side....the window is jumpy and needs to be replaced, any help thank you.
check the motor then, there three little plastic nylon locks in the motor that keep engaugement clean and smooth...=window gear bushings
http://www.latemodelrestoration.com/...indow-Hardware
you'll have to pull the motors out and pull the cover off, most likely you'll find a bunch of little broken plastic pieces in there, but also if thiswere the issue, it'd have issues going up, so inspect the regulator and the slide rail and guides on it, if the guides are gone and or worn out it may be binding on the way down, mine had missing guides and needed gear bushings to fix it
DreadPirateRoberts
09-26-2015 02:11 PM
mungodrums
09-22-2015 08:36 PM
wishinsky
09-21-2015 09:48 AM
