Aluminum vs. Steel Flywheels
I am putting a new Centerforce clutch in my 90 GT and sent the flywheel to the machine shop to be resurfaced and they found cracks in it. So I am going to replace it. Is there a real advantage to Aluminum vs. Steel? Any help is appreciated...
some people will tell you that the car will be hard to get to idle with an aluminum flywheel. and while I agree that the lighter rotating assembly will slow down quicker and CAN cause stalling if the IAC isnt working properly, I do not agree that its faulted by the aluminum flywheel.
I run one in my car, and I dont have any problems. No chattering clutch, no stalling, no bucking etc.
if your car is just going to be used on the street, and DD type stuff, just keep a steel flywheel
No need to risk what was stated above for a measly 10-20 pounds
Even a track car can benefit from a heavy flywheel.
If it's the type that leaves off the limiter the intertia of the heavier wheel will help launch the car. You need serious traction and not a T5 for that level of play.
lol well thats the point of the flywheel. to store rotational energy. a lighter flywheel will have a lower moment of inertia and therefore make it easier for the engine to stall vs a heaver one with a higher moment of inertia.
junior04
09-28-2015 10:53 AM
ccdguy
09-19-2015 05:20 PM
09-10-2015 08:39 PM
