I am currently swapping my AOD to a t5 and i have a few questions that hopefully you all can help me with:
1. Does the AOD crossmember work for the t5?
2. Will the driveshaft and yoke fit the t5?
3. Any changes i might not know about in doing the swap?
4. Which speedometer sensor and gear?
1. no not unless you cut the welds and slide it to proper center position
2.yes but I like to use the t-5 heavier duty one
3. depends on what you know already??
4. depends on what your rear gear ratio currently is??
