through the floor subframe connectors
Did you see the install pics on wolfe craft's site??
http://www.wolferacecraft.com/instal...usthrusub.aspx
actually now that i think about it there was a mustang coupe up there that he was making a 25.5 car with through the floor subframe connectors on. if its still there i was try and run up there in the morning for you
that'd be great. i'm most concerned about seeing the front mount brace to the rocker panel (top and bottom pic). i cant quite visualize how that ties in. the rest of it i see no problems with the kit, pretty straight forward design.
here is mine I have done a few sets and would and will change mine if and when the time comes that I see issues start but for now it is what it is. I just split the subframe and ran them into the front seat support and welded it all up then took a piece of the sub frame box cut it in half wrapped it around the sub and the factory sub and welded them together. I stoped at the factory torque box and plated the front of the box and welded them together. the other car I did I notched the torque box and ran them through it I may do this to mine if I see some movement and when I cut the floor you could get into weld the sub to the rear frame rails also. Some of things I would change is to add a tube to the rockers and make them longer like to the fire wall and like I said run the through the torque boxes. But I am sure they will be fine in a low 9s or high 8s car I have seen less run faster and if I ever run faster then 8.50 it will all have to be cut out anyway. I did this years before the wolf kits came out. Mine are made of 2X3 box that is the same thickness of roll bar tubing and I also welded the whole length of the floor to them. This was the first set I done
thanks broski. deff cleared up a bunch of stuff. question though. whats goin on in pic #2? see where the main square steel is? to the left of it there is some tube steel running into what looks to be a slit cut into the trans tunnel? is that right?
