You would be buying a new rotating assembly which means new pistons that should clear no problem
i will be buying a short block.but i was thinking of getting the afr 185s for my stock bottom end.would i wave to still notch my pistons?
ther site says 86 5.0 has to notch pistons but didnt they chang pistons in 5.0 engines?
Originally Posted by luckythirteen13
extra cubes need more air to make power. there is a guy on this forum that proved that. built a 347, used the stock heads and dynod 286rwhp
see im confused if i were to buy the 347 short block ... to me its a start to a strong powerful motor...because then i will do h/c/i and hopefully hit my mark
or i can do h/c/i on current engine and get short block later?
(which seems like it would be more work)
what if i do a budget 347 what do you/everyone else think?
example:
gt40p heads(may go gt40x if i fell like it )
standard hp cam thats 50 state legal $200-$300 unless theres a cheaper way
and gt40 upper and lower .or a trickflow or edelbrock ..sumthing along those lines
