Intake gasket
#22
That's exactly what it was! I took the cover off, tightened them down (one i backed completely out with my hand), and it quieted right down.
The spiractic idle stopped on it too, for a minute. Let me explain:
We left the distributor hold down clamp loose so we could adjust the distributor housing a bit with it still on the car to get the timing just right. Well, when was pulling it back into the garage, I hit a patch of ice and the car shifted side to side and knocked the distributor out of alignment (didnt come off the gear, but the housing turned a bit), now it wont stay running. Takes alot of cranking for it to even fire up (As it cycles to get to the right firing order). Now I need to find out what the hell happened to it. It stalls out almost immediately now unless you give it gas.
Also gotta do a base idle reset on it. Like an idiot when it was driving smooth like a brand new car, I unplugged iac and the car died. Hasn't been right ever since.
#23
whats the best way to reset timing? The shaft didnt come out of the block only the housing turned. Should i just rotate it some more til its fine or pull out dist. Turn crank so the marks line up and reinsert dis. With rotor facing #1?
daltron
04-28-2016 08:10 PM
