Will i hit my goal with this?
12-17-2009, 03:26 AM
I would like to hit 400 crank hp. I was planning on Afr 185's, performer rpm intake, custom grind cam, and a 100 shot of n2o.
12-17-2009, 06:52 AM
D.R. THE PATHETIC DORK
with a 302 bottom end??? and if your including the n02 as part of the 400 rwhp mark then it should get you there
12-17-2009, 09:57 AM
Quote:
Originally Posted by
mjr46
yes including the nitrous. Sorry forgot to mention stock bottom end, UDP's, shorty headers, topped with a holley 650 double pumper.
12-17-2009, 11:58 AM
the nitrous will get you to 400 at the tires. just the h/c/i will get 400 to the crank.
12-17-2009, 12:00 PM
btw, if you dont have a stall, you might want to get one before the h/c/i.
if they build a custom cam around a stock converter its not going to optimize your set up.
I would get a 2500-3000rpm stall converter
12-17-2009, 04:55 PM
302army187
you get the stall after the motor is built and dynoed. that way you can see where your peak torque is and then order a custom converter accordingly
to the OP, with that setup youll see 400rwhp easily.
12-18-2009, 07:53 AM
luckythirteen13
Thanks. I was planning on doing a stall after the engine was finished. Low 12's will be easy with this set up wont it?
12-18-2009, 12:18 PM
should be a nice little toy when its finished
12-19-2009, 03:26 AM
luckythirteen13
very good point! didn't think of that
83glx5.0
it should run low 12's on motor at sea level with the stall and sticky tires. There is a guy on another board running a 11.60 with trick flow heads, trickflow stage 2 cam, and a good intake, but his car is light as hell, and he can drive like a mad man.
GimpyHSHS
19
12-19-2023 01:12 PM
mungodrums
Suspension
02-09-2016 09:05 AM
09-30-2015 12:39 PM
wraith777
09-28-2015 10:49 AM
