8.8 rear end question
something like this... a gear speed calculator would have worked wonders for you
http://www.google.com/#hl=en&q=gear+...6c7832dbb01be6
my buddy went 3.73 in his notch and i did 4.10 in my first notch
they were both all stock w/ et streets and exhaust... i went 13.60's and he went 14.20's
traded cars to check driver error... pretty much the same thing, i got his down to 14.00 and the car still bogged a bit due to lack of gear, he drove mine about 13.80 and no bog.
swapping a single gearset (3.73 to 4.10) is almost pointless..... the only few times i would EVER consider was to go down numerically if i got a blower (4.10 to 3.73) or up numerically cuz the previous owner didn't know what they were doing or were afraid to go fast (3.73 to 4.10)
unless you make 350 or more REAL hp... your car will be slow with 3.55 or lower numbered gears and is sure to bog if you use a sticky tire.
and FYI, 4.10's on a stock 5-speed can lift the front tire on a 5k launch... can't do that w/ any lower numbered gear not even in an earthquake
the good thing about the 1990 t5 is it has a 7 tooth drive gear... so you can correct the speedo for the 4.10's w/ a new driven gear but have to use the white jeep gear. it will wear out but you will be 100% accurate. the newer t5's and all aod's use a 8t drive gear, and all you can correct to is either 3.27 w/ a ford part or 3.55 with the jeep gear.
more FYI, t5's have a removable drive gear and aod's have a drive gear machined on the output shaft and it is not fixable. t5's the best way to correct is use 6 tooth drive gear(black) then use a 20 tooth driven for 4.10's but the trans needs to be disassembled to swap it out. anytime you rebuild the trans though... spend the $15 for the black drive gear.. it just clips on the output shaft and will allow you to correct to 4.30's w/ ford parts and 4.56 w/ jeep driven gear
91StangOwner
08-20-2015 11:34 PM
Black_GT_02
08-20-2015 01:26 PM
92 5.0stang
08-13-2015 06:46 AM
