Project: DD pics 4/25/10
I pieced my 5 lug conversion together. For the front you will need the spindles, calipers, hubs, rotors, pads, two brake line fitting adapters, and two 5/8 washers per side to use on the ball joint stud. The stud is slightly longer on the fox. I used sn95 struts as well because the fox struts were wider where they meet the sn95 spindle, causing a gap.
Are you planning on discs for the rear? If so all you need to do back there is relocate a rubber line that comes from the rear axle to the hard lines on the car. You will need axels, rotors, calipers, brake line fitting adapters, and pads for the rear as well.
I used a brake booster from my 88 donor car.
5 lug kits are 2500 up, I did mine for just under 600.
yea i am going to piece mine together or try and find a wrecked a sn95 car. i didnt think the fox brake booster was good enough for disc front and back?
It stops like a normal car would but I'm sure I could get more out of it. I plan on upgrading next winter when I do gauges. It's what I had so I used it.
EDIT: Is stopping power sufficient? Answer: Yes.
the way i look at it everyone complains about the fox brakes being junk so i figured that i should do it right from the get go. i guess i should get out there and snap some pics of it
there are two sn95s with good spindles in my local pull a part, I am gonna try to see if I can snag them before I go back to school if I have the $$$ everyone Ive talked to about a 5 lug swap said its the best money theyve spent
it aint pretty im not going to lie. its an 89 hatch car that im going to drop my 302 long block and 5spd swap in. it will be a fuel injected car and have a/c to keep the girlfriend happy. Several the parts for the swap are coming off the POS such as the k-member kit amd 4.10s for sure. id like to do a 5lug swap to it and put some stock wheels on it. it wont have a lot of money in it just some time but should be a nice little car to drive around everywhere
depending on what deals i can find id like to have it on the road by late spring.
