Which timing chain and gear??
I'm going to install a new cam in my 87 gt. I 've done the usual upgrades heads intake exhaust .My question is,Summitt Racing has theSummitt for 38.00 Ford at 63.00 , Comp Cams 35.00 just to name a few or is there much difference?
I use Comp Cams parts. Other people use other companies, and they all seem to work, too. I guess that means you can pick whichever one you want and you'll be OK.
Even though I always install the cam straight up, I get the mutli-indexed set. Then when I check the cam timing, I can easily adjust it if needed. The cam timing is usually spot on. But once in a while it's off 1-2*.
musnicki
09-23-2015 07:11 AM
09-03-2015 07:14 PM
