stock rocker strength
you can read my sig for what i have. i still have the stock rockers. my heads are pretty worked over with five angle vj,bowl work, upgraded springs and hardened push rods. i just put the stockers back on due to cost of the ped mount rr's. i'm allso not sure i'm going to stick with this set up so if i can save having to buy 400 dollar rr's i will. like all mods after two trips i want more so i'm going with a 125 shot and see how long everthing lasts or if i'm happy with what i have i'll keep it. but want to make sure they will last a while with juice.
Your stock rockers should work just fine but that would be the next upgrade IMO before the go juice. You can get a good set of pedestal mount Pro forms for $180.
http://www.latemodelrestoration.com/item/PFM-66879
http://cgi.ebay.com/ebaymotors/cobra...item27ae46536b
addermk2 thanx for the link. with 1.7 rr's will i have any ptv issues.and will the stock valve covers work?
allso my heads were decked when redone. did the cobra have a stock h.o cam with 1.7's?. am i better with the e cam and 1.6's? clearly i have no idea. but if they are good i'll order them right away.
projectresto thanx to you too. i just have this wierd addiction to frpp parts.they fit well together and fit my budget pretty good too!!
the cobra did NOT have an stock HO cam
and the only way to know of any PTV issues is to check yourself. every motor is different
