Suggestions for h/c/i combo?
team z tube k member, coil over front end check
team z adjs upper control arms w/ relocation brackets check
team z adj lower control arms check
full length sub frame connectors check
strange engineering shocks and struts check
stock gt rear springs damn 5 out of 6
put that on drag radials and you'd get yourself low 13's(for a stock mustang that is) and all the suspension you'd ever need for future motor mods.anything you do motor after all that would net you faster and faster times.
Those suspension mods are not going to add much fun on the street. Those are for pulling off great '60's.
For a great street suspension set up, I'd look at either of the following from Maximum Motorsports.
1990-93 Mustang Starter Box includes:
1990-93 Mustang Sport Box includes
You could piece together the above kits for less but these give you an idea of the kind of setup that will improve the way your car handles on the street.
- MM Road & Track Springs
- MM Caster/Camber Plates (select Black or Chrome finish option)
- 2 Bilstein Struts
- 2 Bilstein Shocks
- Front and Rear Urethane Spring Isolators
- MM Urethane Pinion Snubber
- H&R Sport springs
- Tokico Premium Performance struts
- Tokico Premium Performance shocks
- Urethane spring isolators
- MM Pinion Snubber (solid axle Mustangs)
- MM Panhard Bar
- MM Standard Subframe Connectors
- MM Strut Tower Brace
- MM 4-point K-member Brace
- Urethane steering rack bushings
- Front swaybar bushings
- Front swaybar end links
yea it would depend on how serious the person is wanting to go or should i say how fast they are wanting to go so i slightly agree with you.
