Which heads TFS of AFR's NEED HELP?
Things are backed up with him as of lately, due to health issues from what I have heard.....if you are in somewhat of a rush, I'd explore other options such as www.flowtechinduction.com. otherwise the wait may be undetermined....... ED provides such a service too
yea. i'll actually, prossibly, be buying a complete bottom end from nathan over on sbf. its a very lightweight 306 rotationg assembly 28oz imbalance, blue printed oil pump yadda yadda yadda. its a pretty special bottom end, has lots of extras done to it and tons of machine work. 190 TW FAC's, custom cam TLSR, super victor, proform race carb(or custom carb) 1 3/4 LT's, 3" exhaust, flow through mufflers dumped. probably run around 7.5k rpms. suspension from dave over at team Z. tube k member, rolocated upper control arm, adj lower c/a. drag radials, 4.30 ish gear...it'll scream a lil bit.
With the incorrect valve events (aka camshaft)......yup..... not with the correct camshaft/valve train setup......or do you see Escalades, Yukons, etc witch such a torque problem, even though they have 265 cc heads from the factory on a 6.2L (376 ci) truck engine?
170 vs 190 depends on the application. With less than 9.5:1 compression in a road race setup, I'd stay with the 170's if the engine isn't going to operate much over 6k-6.5k rpm. Otherwise with the right cam and some willingness to turn more rpm the 190's will make more power on the top end.
