She runs! but doesn't move PLEASE HELP
I finally was able to start my new build up last night. It sounded great and everything went as planned. However the clutch doesnt engage until I push it down about 3 in. The clutch in the 82 is smaller than the clutch in the 86 that I put in to my car. I tried adjusting my clutch cable by pulling up then pushin down but it didnt fix the problem. Help me please! I want to drive it
Has the cable fallen off the quadrant?
Just asking.....You didn't put your clutch disc in backwards, did you?
Originally Posted by Lazor05
(Post 6800680)
Sorry I will try to explain better. When I push on the pedal it is extremely easy to push until it has moved downwards a few inches then I feel resistance. I feel slack in the cable basically. And I tried pulling the pedal up then pushing down a few times to take the slack out and I can now engage the trans but it grinds unless i stomp on the clutch pedal
Originally Posted by capri debris
(Post 6801202)
The clutch doesn't ENGAGE until you push it down 3 inches??? So when it's all the way up, it's like it's all the way to the floor, then when you push it down 3 inches it engages? What's it do when it's all the way to the floor? I don't think you're explaining something right.
sounds like you need a firewall adjuster
| All times are GMT -5. The time now is 11:45 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
