Purchasing an Electric fan
I live in so-cal and when the hot summer rolls in in a couple months i want my fox to run nice and cool when i take it to the beach so i'm in the market for an electric fan, i already got an aluminum radiator, summit brand, so i was just wondering which fan would you guys recommend and would there be any problems fitting it. i ask the fitting question cause a while back i scrapped an electric fan from a t-bird but i as hesitant to measure the spacing because with the larger thicker aluminum radiator it wouldnt fit.
I heard that an ordinary cheap nothin fancy electric fan does the job fine, true?
http://www.latemodelrestoration.com/...ectric-Fan-Kit
like will this one suffice?
Depends on how thick your radiator is. You need to figure out how much space you have. This may not fit like your t bird fan.
You could always find a fan that pushes instead of pulls and mount it to the other side of the radiator. Look on Summit.
I bought just the standard fan off of summit i think it was $140 or something around there, and it bolted right up to my stock radiator. I wired up a manual switch to make it a little simpler, in Oregon i don't need to use the fan much anyways. I forgot the name of it though, i wanna say like proflow or something like that.
i run a flex a lite variable speed controller. The thing is trick. And because of my blower Im running an svt contour fan. Only fan that would fit that I could find. Car never gets hot EVER now. If your tight on space check out a v6 late 90s dual contour fan
