These are my 94-95 spindles. There are two differences between them and the 96+. Obviously the ABS set-up on the 96+ has a slightly wider wheel base because of the hardware for the sensor. The other difference is the steering arm. The steering arm on mine is horizontal... on 96+ the steering arm bends up and the tie rod connection is one inch higher than it is on these. That is why anyone running 96+ spindles SHOULD install a bump steer kit OR relocated their rack.
