if you get lowering springs plan on getting caster/camber plates. I dont care what you fix, without those on an aftermarket suspension you will rape tires.
The engine cradle is off and needs to be repositioned to provide proper caster.
Strut slot/tower needs to be reassembled. (They plan to move it over a bit?)
Ad an alignment is needed.
Estimated cost by specialty shop including labor and parts: 300.00
It said that it was off from probably a hit to the front. Also the strut towers were slightly off and they would move them over a tad to make the towers aligned.
