best way to store a car?
what are some things you all do to store your cars? For instance with mine i am about to move it to a new location and im...
puttting tarp on the ground
getting some carpet or a wrong to put over it
jacking it up and putting jackstands under so the suspension is unloaded
putting a car cover over it
anything else i can do to make i can keep rust off it?
Other things to consider: If youre not planning on starting her up or cant and condensation is going to be a possibility, fill your gas tank to prevent condensation. If mice are around, place unused dryer sheets in the tailpipes and passenger area.
dryer sheets are cheap so i will snag some. anything else you all do?
I store my 93GT in the garage from about late October to sometime in April (when the CT.weater breaks.) My routine is:
Fill the gas tank
Put in fuel stabalizer
Inflate tires to max psi
Park tires on plywood, over the cement floor
Crack windows
Throw a couple of dryer sheets in the interior
hook-up battery tender.
Fill the gas tank
Crack windows
ah... hmm, make sure the tires are off the ground when you put it on stands to avoid flatspotting the tires.
throw a box of baking soda (the kind you put in the fridge) to keep odors away (unless your interior is gutted then no real point lol
Diode Dynamics
28
05-26-2022 12:02 PM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
