Ford Racing Alphabet Camshafts
Jus wondering wat is so bad about the alphabet cams. Anytime u ask about A-Z ford racing cams the first thing I hear is get rid of it. Jus wondering y? Dats all.
Thanks
Thanks
the lobe profiles are outdated, they are single pattern cams which do nothing to help favor the exhaust side on a sbf, which is generally where an sbf needs the help due to the smaller exhaust valves......IMO they are an average at best cam , I've used many f -cams, and e-cams and custom cams, and never have any of the combos that had letter cams could compare to the matched component set ups
a. They are over 20 years old and OTS cams have come along way.
b. Most people who are asking about them want to use them with stock heads. There is no use in doing a cam swap on a 5.0 if you are using stock E7's.
b. Generally you should spend the extra $100 to get a custom cam that can be optimized for your heads/intake/gear/tire/weight and driving characteristics.
you could all ways run a split ratio rocker arm setup. 1.6s on the intake and 1.7s on the exhaust. it would make them slightly better
i got mine for basically free so thats why i used it but still running the stock rockers...
i will say that the f cam is a good off the shelf turbo cam but thats it. ive seen a motor make 1300fwhp with the f cam.....but just think how much more he would have made with a custom cam.
They do sell mixed ratio rocker sets! cams are so debatable it isnt worth getting wigged over, it is preferance and money, thre fine if you want one, and suck if you dont! there was a statement about the exaust vlv being smaller and a limiting factor in sbf heads, is there a production or aftermarket head with a bigger ex vlv?? it isnt a sbf issue its an all around issue! there would be no need for identical intake and ex vlvs or even a bigger ex vlv than intake, that would compromise the whole function of an internal combustion engine would it not?
That would be kinda like having a severe head cold lol! breathing through your nose and exhaling through your mouth! try it next time you have a stuffy nose!
just for referance! SCC-SCP3047BL and TFS-51400512 i think crane offers a set for stock pedestal type heads!
If you had a abc cam already it`d be worth the rockers but if not buy a dual pattern cam atleast a dual duration cam!
I never said i thought you were wrong or even that i disagreed with you, I didnt infact suggest staggered rockers that was nacanitihs not me, i was just clearifying the point of having to buy 2 sets of rockers, every engine i know of exept rotary have smaller ex vlvs lol, i just didnt understand the SBF specific problem when it is all engines.
(If you had a abc cam already it`d be worth the rockers but if not buy a dual pattern cam atleast a dual duration cam!)
I wasnt suggesting either really just saying if he had a FR cam already he could fix the above stated problem! not bashing anyone at all!
As for my car it isnt done yet i lack the intake i need and some injectors soon as i get it done i`ll post scanned slips not just typed in numbers!
If i had an other wise stock engine and didnt want to tear anything down to swap springs or anything else just a cam i`d just settle for a e cam, some people are just wanting sound, they dont care about the power gain or lose! it`s weird but true! I had a local guy ask me to put in a X-303 just for the sound lol, i told him a rediculous price so i didnt have to deal with it,(i`m sure you know where that was going) completely stock other wise and to top it off it was SD!
