aluminum driveshaft?
Is worth it to pick up an aluminum driveshaft? i read that reduces both unsprung & rotational weight improving acceleration. and reduces driveline vibrations for a smoother ride. so is it worth it i can pick one up for about 320. input and suggestions thanks.
I'm curious if anyone who has done an aluminum ds swap ONLY with no other mods has actually noticed a difference at the track. Rotational inertia is based both on the mass and the center of rotation of the mass, the latter being an exponential effect. Al DS's are larger in diameter to have the necessary strength, so it would seem in most cases that the less mass would be canceled out by a larger distance from the center of rotation. The benefit would probably be more noticeable on a car that had a lighter unspring package as well, lighter wheels and brakes etc.
As far as vibration, that's a balance issue, but the harmonics of rotational speed that destroy DS's are better resisted by stronger and smaller diameter materials. AL has the least resistance, carbon fiber has the most, steel and CM steels are generally better than AL, but mild steel vs Al depends on the DS design. That's why most race teams that can afford it run carbon fiber first, and CM steel with a small diameter second.
Has anyone here actually done an AL DS swap with no other mods at all and picked up any time?
stupid question but you use the rear one correct, i have heard it both ways
http://www.tccoa.com/articles/tranny...n/page17.shtml
Galactic
04-29-2019 02:56 PM
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
Luke9222
10-22-2015 11:55 PM
Matt's 95 Stang
10-05-2015 07:16 AM
