mass air meter question
ok i was told that if im runing a 75mm tb that i should run a 80mm maf sensor is this true?
my set up is a 347 stroker with heads cam and trick frlow R intake on 30lb injectors.
my mass air meter is a 76mm on a 75mm tb.
less restriction, better power. I ran a 75mm on my 302... Do you really want to be running 302 parts?
Right now I still have the same 75mm on my 347, and guess what.... It restricts my intake path like a ****. I'll be swapping out to a 90mm soon
Prime... can you get me some close up pictures of your fuel rails, and hose system. I'm going to be installing a super vic on my car in the next week or so, and havent quite figured out what I want to do with my fuel lines
