Rear axle seal..?
Yea, as adder said axle seals are at the ends of the axle. So if they were leaking your brakes would most likely have gear lube on them if it was bad. If your tubes are leaking I would weld them rather than RTV. But I've worked at a Chrysler dealer and now at a Ford dealer and I've never seen either manufacturers axles ever have issues leaking out of tubes.
Ok well take a look and if its simply from the diff cover (which it likely is), just pop it off, clean out the inside, replace fluids and reseal with some RTV
You mention sealing with blue silicone. should this be wiped on around the outside edge or a thin continuous bead on the machined surfaces of the rear end housing that the gasket gets sandwiched between?
blue should not be used here. You need to use black, or Permatex Right Stuff
11-10-2015 11:39 AM
09-10-2015 08:39 PM
Dragonus18
09-09-2015 01:21 AM
