im also going to be doing a tune up very soon and i found this kit on ebay. i like the picks you made with the wires and cap & rotor. anyone know if this is worth the money or if i should just go with the choices listed in this topic for a little cheaper. sorry if im jacking your thread. i figured this would be helpful to you too. http://cgi.ebay.com/ebaymotors/94-95...Q5fAccessories
that link is not helpful at all... you do NOT want to run platinum plugs in a 5.0
your car has two oxygen sensors, and those just happen to be a common ford sensor
Upon further research, you can also use a bosch 15716
I just questioned it because I was looking at a couple different sites and there where conflicting reports on whether these were the right ones or not.
RockAuto has them for $40.89/each, instead of $74.99/each, but Rock Auto says they are the 4 wire, not the 2 wire like the Summit site. They also have the 15716 sensors for $36.79/each. Wonder why they say rear but will work for the fronts?
That's fine. I appreciated the help you've given. I just don't know why a site like Summit would say they are for the rear, but will work for the front. I also didn't know what the difference was between 2 and 4 wire.
