My build (Pics)
Old 04-21-2010, 03:23 PM
  #21
302army187
302army187's Avatar
Originally Posted by Lazor05
Well I just rebuilt an 86 motor and it does have flat top pistons. I bet I could make my own but that scares me a little. Lot of work If I go too deep
pretty sure you can go almost .050-.100, im unsure, its been a while since I read about it on smallblocktech
Did you use 1.6 rr ?
yes
302army187 is offline
Old 04-21-2010, 06:37 PM
  #22
Lazor05
Lazor05's Avatar
Sweet, well thanks for the help man. And by the way watching your videos sure didnt help me to be content with my build. haha
Lazor05 is offline
Old 04-21-2010, 08:20 PM
  #23
302army187
302army187's Avatar
haha, yea the car is a ton of fun thats for sure! you will get there some day
Old 05-11-2010, 11:32 PM
  #24
Lazor05
Lazor05's Avatar
I am looking at Summits website and it has an option for twisted wedge heads including springs rated for .600 lift and .540 lift. In their catalog it says the difference between the 2 is that the .600 is for a hyd roller, the .540 is for a flat cam. On the website it doesnt say that one is for a specific use. Can I use the .540 lift springs with my hyd roller cam since I dont require the .600 lift?
Lazor05 is offline
Old 05-11-2010, 11:51 PM
  #25
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
^^^^^that is a **** poor and very inaccurate way to judge whether a spring rate is sufficient for XXX cam, I always buy matched springs to the cam I purchase and that often involves removing the springs that come on the heads from the manufactorer. Having the proper spring match to the cam requirements on the head will greatly affect longevity of the valvetrain as well as it's performance/rpm potential
mjr46 is offline
Old 05-12-2010, 06:47 AM
  #26
Lazor05
Lazor05's Avatar
Well I ordered the trickflow stage 1 cam and twickflow heads. So these springs wouldnt be matched for the cam? Would you mind pointing me in the direction of the right springs
Lazor05 is offline
Old 05-13-2010, 11:23 PM
  #27
Lazor05
Lazor05's Avatar
Anyone? Im not quite sure how to match the springs to teh cam. All I know is maximum lift. haha
Lazor05 is offline
Old 05-14-2010, 02:41 AM
  #28
302army187
302army187's Avatar
matching springs to a cam is not the easyest task.
that is why they just go off of lift.
saying that. trickflow does design there springs around there heads/cams. So you will be fine. should you settle for being "just fine" that is up to you.
I made sure I had quality springs for my set up. but I payed my engine builder guy to select the springs when he went over the heads.
Old 05-14-2010, 10:36 AM
  #29
Lazor05
Lazor05's Avatar
Ah gotcha. So what are the disadvantages of not matching springs perfectly? Is that when rocker arm studs break?
Lazor05 is offline
Old 05-14-2010, 11:25 AM
  #30
Slick68
Slick68's Avatar
You also need to consider your rear gears. Gears can make or break your engine setup. I've rode in some fast cars, but my buddies 88 Vert with a stock engine with a few external upgrades and 4.11:1 gears pulls very hard and runs like stink. I was shocked when he told me he wants to change to 3.55's. He said the taller gear would take more advantage of his setup.
I don't know what gear your car has or what an 82 GT would've come with, but you might be surprised what gears would do for your car.
Slick68 is offline
Quick Reply: My build (Pics)
