What should i be reving at?
if you shift quick enuff... use a 5200 chip for your light, that should have you actually banging the shift right about 5400-5500
but play with it alittle, like 200 and 400 lower and higher
don't bother with the stock tach... it's useless at hi r's
however high you can without breaking loose.
if the tires squeal.. you launched too hard or dropped the clutch too fast.
if they went " eh eh eh eh eh " then you did good
and that all depends on the tire.
if you CAN get 2.0's on stock radials your driving good.
if you CAN'T get 1.7's on cheaters, your doing bad
and no... nittos are NOT cheaters.... they are like stock radials and a waste of space
GrayGhost01GT
17
08-07-2004 03:27 AM
