Built 408. I figured that might need a slightly different tune then a stock 302...
I also found out it doesn't have a "computer" in it right now, should i just find a stock one from the same year of the car or will a 408 require a different "computer"?
NICE! stock computer for that year will work fine. the windsor and the 302 use the same firing order so as far as the computer is concerned, you just have more air into the motor then a stock 302 but your tuner can take care of that
Alright cool, thanks for the info. Is a computer from a 93 gt any different then one say from a 87 lx or something? Just wondering what years are compatible in case i can find the same computer from a different year cheaper, if you can follow what im saying haha.
supposedly the auto computer had a more aggressive timing curve but your dyno tuner will write you a custom timing curve when your on the dyno, so it wont matter either way
Ohh, i forgot to add, he said it needs a "air flow meter", im assuming he meant mass air flow sensor correct? If so, what size MAF should i use with a built 408?
I was looking at MAF's on Jegs, and for each one is says what injectors they are for, not wht mm they are. Why is this? It has 55lbs injectors if that matters...
