opinions on flycutting pistons in the block
im concerned...in theory if all slugs didnt have exact material removed off the tops of the pistons perfectly wont it throw off engine balance??? im thinking theory here, and have seen peoples actual dremel work that didnt look so hot while others take theirs to a machine shop, while others pull the pistons out and get them cut. what do you guys recommend and why
if machining prices are as bad everywhere else as they are here, it'll be cheaper to just buy new pistons. if you want to use the old ones, pull 'em out. the one metal shaving that doesn't get cleaned out of the bores will haunt you later.
my buddy did to his, he had a fresh bottom end, n when he flycut his, him n his dad put clay around the valve reliefs n did their work.
he had a set of AFR 185 heads, n was gonna build his bottom end until he found out it was a fresher rebuild.
great info man and everyone else just what i want to hear. Looks like i'm going to do it right and pull the slugs ill talk to the machine shop maybe ill punch it out to a 306 we'll see what everything looks like when i strip it down. Thanks guys
Matt's 95 Stang
10-05-2015 07:16 AM
